Inleiding
If you have problems with the motherboard, or the motherboard needs to be replaced or repaired, use this guide to remove and replace your motherboard.
Wat je nodig hebt
Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
Remove additional screws that can be found on the motherboard.
Remove the green wifi card from motherboard.
Use spudger to disconnect the fan and motherboard from laptop.
Bijna klaar!
Conclusie
