Ga door naar hoofdinhoud
Acer Aspire 774G-58GS Thermal Paste Replacement
Wat je nodig hebt
  1. Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: stap 1, afbeelding 1 van 3 Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: stap 1, afbeelding 2 van 3 Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: stap 1, afbeelding 3 van 3
    • Remove the three screws from the plate that covers the RAM and HDD using a Phillips #0 screwdriver.
    • Remove the plate from the laptop.
  2. Acer Aspire 774G-58GS Thermal Paste Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 774G-58GS Thermal Paste Replacement: stap 2, afbeelding 2 van 2
    • Remove the DVD drive and the three screws that are underneath it.
    • Remove all the screws surrounding the backplate.
  3. Acer Aspire 774G-58GS Thermal Paste Replacement: stap 3, afbeelding 1 van 3 Acer Aspire 774G-58GS Thermal Paste Replacement: stap 3, afbeelding 2 van 3 Acer Aspire 774G-58GS Thermal Paste Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the speaker wire beneath the RAM.
    • Gently remove the backplate from the laptop.
  4. Acer Aspire 774G-58GS Thermal Paste Replacement: stap 4, afbeelding 1 van 2 Acer Aspire 774G-58GS Thermal Paste Replacement: stap 4, afbeelding 2 van 2
    • Remove the five screws from the heat sink.
    • Take a cotton ball and dab it with isopropyl alcohol.
    • Use the cotton ball to wipe the old thermal paste from the heat sink.
  5. Acer Aspire 774G-58GS Thermal Paste Replacement: stap 5, afbeelding 1 van 3 Acer Aspire 774G-58GS Thermal Paste Replacement: stap 5, afbeelding 2 van 3 Acer Aspire 774G-58GS Thermal Paste Replacement: stap 5, afbeelding 3 van 3
    • Take another cotton ball, dab it with isopropyl alcohol, and gently wipe the thermal paste off of the GPU and CPU.
    • There is no need to rub hard as it should come off with ease.
    • Once the thermal paste is completely off, let the heat sink dry for a couple of minutes.
    • Apply a dab of new thermal paste in the middle of the CPU and GPU.
    • Corsair TM30 thermal paste is used in this guide.
  6. Acer Aspire 774G-58GS Thermal Paste Replacement: stap 6, afbeelding 1 van 1
    • Put the heatsink back on and screw it in place.
Conclusie
Abdul Munam Khan
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 27
Altijd: 645
