Inleiding
Before replacing the LCD module, make sure to back up your laptop.
Wat je nodig hebt
Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
Use the Phillips #1 screwdriver to remove the two 6.5mm Phillips #1 screws.
Use the Phillips #1 screwdriver to remove the three 4.5mm Phillips #1 screws.
Één andere persoon heeft deze handleiding voltooid.
