Ga door naar hoofdinhoud
Acer Aspire 6530-6522 Hard Drive Replacement
Wat je nodig hebt
  1. Acer Aspire 6530-6522 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Aspire 6530-6522 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 6530-6522 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 Hard Drive Replacement: stap 3, afbeelding 1 van 3 Acer Aspire 6530-6522 Hard Drive Replacement: stap 3, afbeelding 2 van 3 Acer Aspire 6530-6522 Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 Hard Drive Replacement: stap 4, afbeelding 1 van 3 Acer Aspire 6530-6522 Hard Drive Replacement: stap 4, afbeelding 2 van 3 Acer Aspire 6530-6522 Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  5. Acer Aspire 6530-6522 Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 3 Acer Aspire 6530-6522 Hard Drive Replacement, Hard Drive: stap 5, afbeelding 2 van 3 Acer Aspire 6530-6522 Hard Drive Replacement, Hard Drive: stap 5, afbeelding 3 van 3
    • Using the Phillips #1 screwdriver remove the nine 7mm screws in the bottom panel.
    • Lift and remove the panel.
  6. Acer Aspire 6530-6522 Hard Drive Replacement: stap 6, afbeelding 1 van 2 Acer Aspire 6530-6522 Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Grasp the attached tab and pull towards the back of the device.
    • Lift the front end of the hard drive up. Use a plastic opening tool if necessary.
  7. Acer Aspire 6530-6522 Hard Drive Replacement: stap 7, afbeelding 1 van 2 Acer Aspire 6530-6522 Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Lift the hard drive with its casing free of the device and place on a clean surface.
    • Using the Phillips #1 screwdriver, remove the four 3.5mm screws in the corners of the casing.
  8. Acer Aspire 6530-6522 Hard Drive Replacement: stap 8, afbeelding 1 van 2 Acer Aspire 6530-6522 Hard Drive Replacement: stap 8, afbeelding 2 van 2
    • Lift the casing off the hard drive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Patrick McKenna
656 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S5-G6, Peak Spring 2018 Lid van UMass Dartmouth, Team S5-G6, Peak Spring 2018
UMASSD-PEAK-S18S5G6
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 888
