Ga door naar hoofdinhoud
Acer Aspire 5742 Hard Drive Removal
Wat je nodig hebt
  1. Acer Aspire 5742 Hard Drive Removal, Battery: stap 1, afbeelding 1 van 3 Acer Aspire 5742 Hard Drive Removal, Battery: stap 1, afbeelding 2 van 3 Acer Aspire 5742 Hard Drive Removal, Battery: stap 1, afbeelding 3 van 3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Hard Drive Removal, Cover Panel: stap 2, afbeelding 1 van 3 Acer Aspire 5742 Hard Drive Removal, Cover Panel: stap 2, afbeelding 2 van 3 Acer Aspire 5742 Hard Drive Removal, Cover Panel: stap 2, afbeelding 3 van 3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 Hard Drive Removal: stap 3, afbeelding 1 van 3 Acer Aspire 5742 Hard Drive Removal: stap 3, afbeelding 2 van 3 Acer Aspire 5742 Hard Drive Removal: stap 3, afbeelding 3 van 3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 Hard Drive Removal, Hard drive: stap 4, afbeelding 1 van 3 Acer Aspire 5742 Hard Drive Removal, Hard drive: stap 4, afbeelding 2 van 3 Acer Aspire 5742 Hard Drive Removal, Hard drive: stap 4, afbeelding 3 van 3
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
Conclusie
16 andere personen hebben deze handleiding voltooid.
Skylar MacDonald
1.964 Reputatie
5 handleidingen geschreven
4 opmerkingen
Great guide except for the missing screw sizes. Does anybody know the screw sizes?
patrickscott - Antwoord
I have this laptop with a bad HDD, it was a Toshiba 640 GB , 5400 RPM drive.
I like to know if this laptop supports 7200 RPM drives
Also, does this laptop support an SSD drive ?
Shahzaan - Antwoord
Yes, any 2.5in SATA HDD or SSD can be fitted in place of any other.
Philip Le Riche -
I love this guide! It's the best! Thank You!
Mark Wiens - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 69
Altijd: 45,298
