Ga door naar hoofdinhoud
Acer Aspire 5742 CMOS Battery Replacement
Wat je nodig hebt
  1. Acer Aspire 5742 CMOS Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Acer Aspire 5742 CMOS Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Acer Aspire 5742 CMOS Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: stap 2, afbeelding 1 van 3 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: stap 2, afbeelding 2 van 3 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: stap 2, afbeelding 3 van 3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 CMOS Battery Replacement: stap 3, afbeelding 1 van 3 Acer Aspire 5742 CMOS Battery Replacement: stap 3, afbeelding 2 van 3 Acer Aspire 5742 CMOS Battery Replacement: stap 3, afbeelding 3 van 3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: stap 4, afbeelding 1 van 2 Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: stap 4, afbeelding 2 van 2
    • After removing the cover panel, you will see the hard drive, the RAM, and the CMOS battery.
    • The CMOS battery is the silver coin-like object in the center.
  5. Acer Aspire 5742 CMOS Battery Replacement: stap 5, afbeelding 1 van 3 Acer Aspire 5742 CMOS Battery Replacement: stap 5, afbeelding 2 van 3 Acer Aspire 5742 CMOS Battery Replacement: stap 5, afbeelding 3 van 3
    • Press the tip of the spudger underneath the CMOS battery with very slight force.
    • Press down on the opposite side of the battery while prying the battery upward with the spudger.
    • After the battery is mostly lifted from the slot, you may pull out the battery with your fingers.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Bill Murray
581 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G6
3 Leden
8 handleidingen geschreven
Één opmerking
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 116
Altijd: 14,349
