Ga door naar hoofdinhoud
Acer Aspire 5734z-4836 Screen Replacement
Wat je nodig hebt
  1. Acer Aspire 5734z-4836 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Screen Replacement: stap 3, afbeelding 1 van 2 Acer Aspire 5734z-4836 Screen Replacement: stap 3, afbeelding 2 van 2
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Screen Replacement, Screen: stap 4, afbeelding 1 van 2 Acer Aspire 5734z-4836 Screen Replacement, Screen: stap 4, afbeelding 2 van 2
    • Remove rubber bumpers from each four corners to expose the hidden screws that hold the screen bezel in place.
  5. Acer Aspire 5734z-4836 Screen Replacement: stap 5, afbeelding 1 van 1
    • Extract the hidden screws from each of the bezel's four corners, using a #00 Phillips screwdriver.
  6. Acer Aspire 5734z-4836 Screen Replacement: stap 6, afbeelding 1 van 1
    • Pop the bezel loose along the edges with a plastic opening tool.
  7. Acer Aspire 5734z-4836 Screen Replacement: stap 7, afbeelding 1 van 2 Acer Aspire 5734z-4836 Screen Replacement: stap 7, afbeelding 2 van 2
    • Gently pry off the bezel by holding each edge of the bezel with a forefinger and applying pressure onto the screen with your thumbs.
    • Lift the bezel away completely.
  8. Acer Aspire 5734z-4836 Screen Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the middle screw on the green strip under the screen.
  9. Acer Aspire 5734z-4836 Screen Replacement: stap 9, afbeelding 1 van 2 Acer Aspire 5734z-4836 Screen Replacement: stap 9, afbeelding 2 van 2
    • Gently detach the red-and-white cable from the right end of the green strip under the screen.
  10. Acer Aspire 5734z-4836 Screen Replacement: stap 10, afbeelding 1 van 2 Acer Aspire 5734z-4836 Screen Replacement: stap 10, afbeelding 2 van 2
    • Locate six small screws, three on each side of the screen.
    • Remove all six screws with a #000 Phillips screwdriver.
  11. Acer Aspire 5734z-4836 Screen Replacement: stap 11, afbeelding 1 van 2 Acer Aspire 5734z-4836 Screen Replacement: stap 11, afbeelding 2 van 2
    • Disconnect wires from the webcam located above the screen.
  12. Acer Aspire 5734z-4836 Screen Replacement: stap 12, afbeelding 1 van 3 Acer Aspire 5734z-4836 Screen Replacement: stap 12, afbeelding 2 van 3 Acer Aspire 5734z-4836 Screen Replacement: stap 12, afbeelding 3 van 3
    • Lift the screen up from the laptop and turn it around.
    • Gently peel back the tape located behind the screen.
  13. Acer Aspire 5734z-4836 Screen Replacement: stap 13, afbeelding 1 van 2 Acer Aspire 5734z-4836 Screen Replacement: stap 13, afbeelding 2 van 2
    • Pull the connector straight down to remove it.
    • You can now safely lift the screen out of the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Susan Cao
121 Reputatie
1 Handleiding geschreven
CSU Fullerton, Team 2-3, Bruce Fall 2016 Lid van CSU Fullerton, Team 2-3, Bruce Fall 2016
CSUF-BRUCE-F16S2G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 840
