Ga door naar hoofdinhoud
Acer Aspire 5734z-4836 Fan Replacement
Wat je nodig hebt
  1. Acer Aspire 5734z-4836 Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Fan Replacement: stap 2, afbeelding 1 van 1
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Fan Replacement: stap 3, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 3, afbeelding 2 van 2
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Fan Replacement, Keyboard: stap 4, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement, Keyboard: stap 4, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement, Keyboard: stap 4, afbeelding 3 van 3
    • Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
    • By using a bit of force some clicks will be heard when removing the cover.
  5. Acer Aspire 5734z-4836 Fan Replacement: stap 5, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 5, afbeelding 2 van 2
    • Pull the keyboard off gently so not to damage the keyboard ribbon cable.
    • Multiple clicks may be heard as you pull the keyboard off.
  6. Acer Aspire 5734z-4836 Fan Replacement: stap 6, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 6, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 6, afbeelding 3 van 3
    • Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
    • Pull the blue keyboard ribbon cable from the ZIF connector.
    • When reinstalling a new keyboard, insert the ribbon in the same way the old keyboard's ribbon was removed.
  7. Acer Aspire 5734z-4836 Fan Replacement, Base Assembly: stap 7, afbeelding 1 van 1
    • Begin with the laptop placed on its bottom and the empty keyboard space facing you.
  8. Acer Aspire 5734z-4836 Fan Replacement: stap 8, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 8, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the screen connector in the upper left of the laptop.
  9. Acer Aspire 5734z-4836 Fan Replacement: stap 9, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 9, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 9, afbeelding 3 van 3
    • Locate the tape on the upper left of the laptop.
    • Peel off the tape, covering the red-and-black wire connector and the white-and-black speaker wires.
  10. Acer Aspire 5734z-4836 Fan Replacement: stap 10, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 10, afbeelding 2 van 2
    • Gently disconnect the red-and-black wire connector and the white-and-black speaker wires from the upper-left.
  11. Acer Aspire 5734z-4836 Fan Replacement: stap 11, afbeelding 1 van 1
    • Remove the 5 screws in the middle of the laptop using a #00 Phillips Screwdriver.
    • In order to access the screw in the upper left corner, you may have to gently move the red and white wires.
  12. Acer Aspire 5734z-4836 Fan Replacement: stap 12, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 12, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 12, afbeelding 3 van 3
    • Disconnect the two blue and white ribbons by applying pressure downward and pushing them out of their sockets.
  13. Acer Aspire 5734z-4836 Fan Replacement: stap 13, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 13, afbeelding 2 van 2
    • Remove the four screws from the upper corners of the laptop using a Phillips #00 screwdriver.
    • The two metal and two plastic connectors will come free. Save them in a safe place.
  14. Acer Aspire 5734z-4836 Fan Replacement: stap 14, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 14, afbeelding 2 van 2
    • Pop off the black plastic hinge coverings.
  15. Acer Aspire 5734z-4836 Fan Replacement: stap 15, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 15, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Peel away the sticky plastic coverings with tweezers.
  16. Acer Aspire 5734z-4836 Fan Replacement: stap 16, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 16, afbeelding 2 van 2
    • Remove the three screws with a #00 Philips Screwdriver.
  17. Acer Aspire 5734z-4836 Fan Replacement: stap 17, afbeelding 1 van 1
    • Remove the single screw next to the right hinge with a #00 Phillips Screwdriver.
  18. Acer Aspire 5734z-4836 Fan Replacement: stap 18, afbeelding 1 van 1
    • Flip the device so the bottom of the laptop is face-up.
  19. Acer Aspire 5734z-4836 Fan Replacement: stap 19, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 19, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 19, afbeelding 3 van 3
    • Remove the fifteen screws from the back of the laptop with a Phillips #00 Screwdriver.
  20. Acer Aspire 5734z-4836 Fan Replacement: stap 20, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 20, afbeelding 2 van 2
    • Pry mid-back panel off.
    • Use a plastic opening tool.
  21. Acer Aspire 5734z-4836 Fan Replacement: stap 21, afbeelding 1 van 1
    • Lift the hard-drive cover in the bottom right corner off the laptop.
  22. Acer Aspire 5734z-4836 Fan Replacement: stap 22, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 22, afbeelding 2 van 2
    • Slide down the hard-drive out of the laptop.
  23. Acer Aspire 5734z-4836 Fan Replacement: stap 23, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 23, afbeelding 2 van 2
    • Peel away the black plastic covering under the mid-back panel.
  24. Acer Aspire 5734z-4836 Fan Replacement: stap 24, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 24, afbeelding 2 van 2
    • Remove the two screws on the left and bottom of the circuit board with a #00 Phillips Screwdriver.
  25. Acer Aspire 5734z-4836 Fan Replacement: stap 25, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 25, afbeelding 2 van 2
    • Disconnect the black and white wires on the small circuit board by gently pulling them out of their sockets.
  26. Acer Aspire 5734z-4836 Fan Replacement: stap 26, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 26, afbeelding 2 van 2
    • Remove the four screws from the metal piece beneath the circuit with a Phillips #000 Screwdriver.
  27. Acer Aspire 5734z-4836 Fan Replacement: stap 27, afbeelding 1 van 1
    • Life the metal plate free and place it somewhere for safe-keeping.
  28. Acer Aspire 5734z-4836 Fan Replacement: stap 28, afbeelding 1 van 1
    • The small circuit board will pop up easily. Carefully remove it
  29. Acer Aspire 5734z-4836 Fan Replacement: stap 29, afbeelding 1 van 1
    • Gently extract the black and white wires. They will pull free from the base through the hole in the upper left corner.
  30. Acer Aspire 5734z-4836 Fan Replacement: stap 30, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 30, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 30, afbeelding 3 van 3
    • Flip to the front and gently lift the front of the laptop off of the base.
    • Some wires will be pulled up from the base so be careful not to pull it away too quickly.
  31. Acer Aspire 5734z-4836 Fan Replacement, Fan: stap 31, afbeelding 1 van 1
    • Position the back panel so that the circuit board is face-up.
    • Location of the fan is in the upper-left corner.
  32. Acer Aspire 5734z-4836 Fan Replacement: stap 32, afbeelding 1 van 1
    • Unscrew five screws from the circuit board using a #00 Phillips screwdriver.
    • Two screws are located below the fan, and three are along the circuit board's right edge.
    • Take note of the one black screw that goes in the lower-right corner.
  33. Acer Aspire 5734z-4836 Fan Replacement: stap 33, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 33, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 33, afbeelding 3 van 3
    • The large, silver box next to the circuit board is the optical disk drive, gently slide to the right to remove it.
    • Do not apply too much pressure on the optical disk drive, as you may risk damaging the disk drive's connector.
  34. Acer Aspire 5734z-4836 Fan Replacement: stap 34, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 34, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 34, afbeelding 3 van 3
    • Lift the circuit board out of the back panel and turn it over so the fan is facing up.
  35. Acer Aspire 5734z-4836 Fan Replacement: stap 35, afbeelding 1 van 2 Acer Aspire 5734z-4836 Fan Replacement: stap 35, afbeelding 2 van 2
    • Locate the three screws around the fan
    • Gently extract three fan screws using #0 Phillips.
  36. Acer Aspire 5734z-4836 Fan Replacement: stap 36, afbeelding 1 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 36, afbeelding 2 van 3 Acer Aspire 5734z-4836 Fan Replacement: stap 36, afbeelding 3 van 3
    • Disconnect the white fan connector.
    • Grip gently the wire and pull the wires up toward you.
  37. Acer Aspire 5734z-4836 Fan Replacement: stap 37, afbeelding 1 van 1
    • Remove the fan from the circuit board.
    • Due to the accumulated dust inside the fan, you may want to use a small brush to clean off dust.
Conclusie
Steven Loon
291 Reputatie
2 handleidingen geschreven
CSU Fullerton, Team 2-3, Bruce Fall 2016 Lid van CSU Fullerton, Team 2-3, Bruce Fall 2016
CSUF-BRUCE-F16S2G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 1,186
