Ga door naar hoofdinhoud
Acer Aspire 5534-1146 Hard Drive Replacement
Wat je nodig hebt
  1. Acer Aspire 5534-1146 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Locate where the hard drive is located on the back side of the laptop and unscrew the two .8cm Long screws.
  2. Acer Aspire 5534-1146 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Once you have have removed the back panel cover, find the hard drive’s location.
  3. Acer Aspire 5534-1146 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Find and locate the two screws that are 0.8cm long that are holding the hard drive in place to the back metal plate.
    • Carefully take a PH #0 screwdriver and remove the two screws.
  4. Acer Aspire 5534-1146 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Once you have unscrewed the two screws, carefully slide the hard drive the opposite direction of the screws that you just removed, slide the drive till it is free.
    • You are now ready to remove the hard drive from it’s compartment from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 481
