Ga door naar hoofdinhoud
Acer Aspire 5534-1146 Battery Replacement
Wat je nodig hebt
  1. Acer Aspire 5534-1146 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure your device is unplugged from the power source . Gently turn it over, and lay it on a flat on its face.
  2. Acer Aspire 5534-1146 Battery Replacement: stap 2, afbeelding 1 van 1
    • This latch locks your battery in place, it should always be locked with the exception of replacement. Slide it horizontally to the unlock position.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5534-1146 Battery Replacement: stap 3, afbeelding 1 van 1
    • Locate the latch that ejects the battery (top right corner) and push it to the left, so the battery can come out.
    • The battery will pull out once the latch is positioned to the left.
    • You DO NOT need to push on the ejecting latch when replacing the new battery, it will snap into place itself.
  4. Acer Aspire 5534-1146 Battery Replacement: stap 4, afbeelding 1 van 1
    • Push the battery forward and it will slide out, it should come out with ease. There should be a label with the part number.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 451
