Ga door naar hoofdinhoud
Acer Aspire 5534-1096 Battery Replacement
  1. Acer Aspire 5534-1096 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Disconnect laptop from electric source prior to any repair.
    • On the bottom side of the laptop, you will unlock the safety lock by sliding it towards the left.
  2. Acer Aspire 5534-1096 Battery Replacement: stap 2, afbeelding 1 van 1
    • Now, you'll hold this latch to the left. Everything is unlatched. The battery should feel free.
  3. Acer Aspire 5534-1096 Battery Replacement: stap 3, afbeelding 1 van 3 Acer Aspire 5534-1096 Battery Replacement: stap 3, afbeelding 2 van 3 Acer Aspire 5534-1096 Battery Replacement: stap 3, afbeelding 3 van 3
    • While continuing to hold the latch in the open position, use your other hand to push the battery away from the device to remove it.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 312
