Inleiding
This guide will lead you through the steps of removing the USB Add-on Card attached on the motherboard.
Wat je nodig hebt
Locate and remove the 5 screws that secure the panel over the RAM and CPU cover on the upper right hand side. These can be found in the center towards the corner opposite the battery compartment.
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Één opmerking
اello
I have a problem at all entrances usb not working
When Enter the device show me unknown device
The show I've been arrested for this device that caused the problem (code 43)
I did not understand the problem, despite all attempts
Where do I start testing now, sir
I hope to answer in the near future sir
Thank you
