Ga door naar hoofdinhoud
Acer Aspire 5100 RAM Replacement
Wat je nodig hebt
  1. Acer Aspire 5100 RAM Replacement, RAM: stap 1, afbeelding 1 van 2 Acer Aspire 5100 RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Remove the screws on the large panel.
    • Lift up the panel.
  2. Acer Aspire 5100 RAM Replacement: stap 2, afbeelding 1 van 3 Acer Aspire 5100 RAM Replacement: stap 2, afbeelding 2 van 3 Acer Aspire 5100 RAM Replacement: stap 2, afbeelding 3 van 3
    • The RAM slots are located in the corner opposite to the cooling fan.
    • To remove existing RAM cards: there are clips holding the sides of each card. Simultaneously spread both right and left clip and the card will pop upward. Then it can easily be pulled out.
    • Slide in the RAM at a 45 degree angle.
    • Press down on the RAM until it snaps into place.
    • A good amount of pressure is needed to snap it in place.
    • Install the RAM in the left (lower) slot before installing RAM in the right (upper) slot
Conclusie
7 andere personen hebben deze handleiding voltooid.
Brad Rollinson
1.113 Reputatie
7 handleidingen geschreven
Cal Poly, Team 14-39, Forte Fall 2010 Lid van Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Leden
10 handleidingen geschreven
Één opmerking
being a novice ram replacement i found this to be exactly what i needed to know thankyou very much.
bruce johnson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 23
Altijd: 16,300
