Ga door naar hoofdinhoud
Acer Aspire 5100 LCD Monitor Replacement
Wat je nodig hebt
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: stap 1, afbeelding 1 van 2 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: stap 2, afbeelding 1 van 3 Acer Aspire 5100 LCD Monitor Replacement: stap 2, afbeelding 2 van 3 Acer Aspire 5100 LCD Monitor Replacement: stap 2, afbeelding 3 van 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: stap 3, afbeelding 1 van 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
    do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
    steve foss - Antwoord
    useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
    Valerio Vischio - Antwoord
    You do not need to remove the whole cover, in order to replace the keyboard.
    The description for this job is right.
    The switch plate cover just pops off.
    Screws revealed, secure the keyboard.
    Unclip the ribbon cable.
    Job done
    Richard -
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: stap 4, afbeelding 1 van 1
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: stap 5, afbeelding 1 van 2 Acer Aspire 5100 LCD Monitor Replacement: stap 5, afbeelding 2 van 2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: stap 6, afbeelding 1 van 2 Acer Aspire 5100 LCD Monitor Replacement: stap 6, afbeelding 2 van 2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: stap 7, afbeelding 1 van 1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: stap 8, afbeelding 1 van 1
    • Lift up the monitor to detach it.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Brad Rollinson
1.113 Reputatie
7 handleidingen geschreven
Cal Poly, Team 14-39, Forte Fall 2010 Lid van Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Leden
10 handleidingen geschreven
Één opmerking
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 15,435
