Ga door naar hoofdinhoud
Acer Aspire 5100 LCD Monitor Replacement
Wat je nodig hebt
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: stap 1, afbeelding 1 van 2 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: stap 2, afbeelding 1 van 3 Acer Aspire 5100 LCD Monitor Replacement: stap 2, afbeelding 2 van 3 Acer Aspire 5100 LCD Monitor Replacement: stap 2, afbeelding 3 van 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: stap 3, afbeelding 1 van 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: stap 4, afbeelding 1 van 1
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: stap 5, afbeelding 1 van 2 Acer Aspire 5100 LCD Monitor Replacement: stap 5, afbeelding 2 van 2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: stap 6, afbeelding 1 van 2 Acer Aspire 5100 LCD Monitor Replacement: stap 6, afbeelding 2 van 2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: stap 7, afbeelding 1 van 1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: stap 8, afbeelding 1 van 1
    • Lift up the monitor to detach it.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Brad Rollinson
1.113 Reputatie
7 handleidingen geschreven
Cal Poly, Team 14-39, Forte Fall 2010 Lid van Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Leden
10 handleidingen geschreven
1Gids Commentaar
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 15,791
