Ga door naar hoofdinhoud
Acer Aspire 5 A515-43-R19L RAM Replacement
Wat je nodig hebt
  1. Acer Aspire 5 A515-43-R19L RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Place your device with the top facing down.
    • Make sure the primary exhaust is facing away from you.
  2. Acer Aspire 5 A515-43-R19L RAM Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 2, afbeelding 2 van 2
    • Remove the nine screws from the bottom of the laptop using a Phillips #1 screwdriver.
  3. Acer Aspire 5 A515-43-R19L RAM Replacement: stap 3, afbeelding 1 van 3 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 3, afbeelding 2 van 3 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 3, afbeelding 3 van 3
    • Use a prying tool to separate the case from the laptop.
    • As you reach the exhausts and screen hinges, be especially careful. Too much force may cause unforeseen damage.
    • Potential device damage: Avoid pushing too far into the device during this process, as you may apply unnecessary force to the sensitive internals.
  4. Acer Aspire 5 A515-43-R19L RAM Replacement: stap 4, afbeelding 1 van 3 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 4, afbeelding 2 van 3 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 4, afbeelding 3 van 3
    • With any step working on the device's internals, keep direct contact with any components to a minimum. This is doubly true for your exposed skin.
    • While this step is not necessary, it is common practice to reduce the chances of things going wrong. (i.e "bricking" your device).
    • Use an opening tool to detach the battery connector from the motherboard.
  5. Acer Aspire 5 A515-43-R19L RAM Replacement: stap 5, afbeelding 1 van 3 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 5, afbeelding 2 van 3 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 5, afbeelding 3 van 3
    • You'll find RAM slots north of the battery connection point and to the right of the copper pieces.
    • Lightly grip and push both sides of the RAM housing in opposite directions until the RAM pops up from the slot at an angle.
    • Pull the RAM free from the slot.
  6. Acer Aspire 5 A515-43-R19L RAM Replacement: stap 6, afbeelding 1 van 3 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 6, afbeelding 2 van 3 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 6, afbeelding 3 van 3
    • Align your RAM's DIMMs so the shorter side slots into the shorter space and the larger side slots into the larger space.
    • Insert the RAM at an angle.
    • Press down on the stick until the bearings on both sides click into place.
  7. Acer Aspire 5 A515-43-R19L RAM Replacement: stap 7, afbeelding 1 van 2 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 7, afbeelding 2 van 2
    • Reconnect the battery to the motherboard.
  8. Acer Aspire 5 A515-43-R19L RAM Replacement: stap 8, afbeelding 1 van 2 Acer Aspire 5 A515-43-R19L RAM Replacement: stap 8, afbeelding 2 van 2
    • Place the shell back onto the laptop, clicking each corner and side into place.
    • Screw the shell back onto the laptop.
Eindstreep
Troy Rana
175 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 64
Altijd: 264
