Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide will show detailed steps to carefully disassemble the laptop, and replace the internal hard drive.
Onderdelen
Geen onderdelen opgegeven.
  1. Lay the laptop upside down. Locate and unscrew the  seven phillips head screws.
    • Lay the laptop upside down.
    • Locate and unscrew the seven phillips head screws.
  2. Remove the cover panel from the laptop
    • Remove the cover panel from the laptop
  3. Remove the hard drive from the laptop by using a Spudger tool to pry it out. Remove the hard drive from the laptop by using a Spudger tool to pry it out. Remove the hard drive from the laptop by using a Spudger tool to pry it out.
    • Remove the hard drive from the laptop by using a Spudger tool to pry it out.
Conclusie
Antonio Kittrell
101 Reputatie
1 Handleiding geschreven
Één commentaar
Yes, but how do you get the hard drive out of its carrier, for example in order to replace it with an SSD?
Philip Le Riche - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 275
