Ga door naar hoofdinhoud
Acer Aspire 4743-6481 Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire 4743-6481 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Keyboard Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Remove the two 6.0 mm screws that secure the keyboard using a Phillips head screwdriver.
    • They can be easily identified by looking for the screws with the keyboard icon next to them.
  5. Acer Aspire 4743-6481 Keyboard Replacement: stap 5, afbeelding 1 van 2 Acer Aspire 4743-6481 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Turn the laptop over and open it.
    • Use flat edged tools to gently separate the keyboard from the laptop. It should snap off with a small amount of force.
    • Be sure to push the small tabs along the top of the keyboard, while lifting to successfully free the keyboard.
  6. Acer Aspire 4743-6481 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Gently lift away the keyboard, making sure not to damage the data cable or the connector.
    • The connection is located beneath the bottom center of the keyboard.
  7. Acer Aspire 4743-6481 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Remove piece of tape that covers the connection between the data cable and the connector.
  8. Acer Aspire 4743-6481 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Detach the data cable by flipping up the small black latch on the connector.
    • Once the latch is lifted, the keyboard should be completely free.
Conclusie
3 andere personen hebben deze handleiding voltooid.
David Veres
140 Reputatie
1 Handleiding geschreven
USF Tampa, Team S5-G1, Lacy Spring 2017 Lid van USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 1,380
