Ga door naar hoofdinhoud
Acer Aspire 4741G-332G32Mn Motherboard Replacement
Wat je nodig hebt
  1. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the lock latch to unlock battery.
  2. Acer Aspire 4741G-332G32Mn Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the middle latch and remove the battery.
  3. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: stap 3, afbeelding 1 van 3 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: stap 3, afbeelding 2 van 3 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: stap 3, afbeelding 3 van 3
    • Pry off the keyboard using the opening tool.
    • Remove the two screws that are connected to the motherboard using a Phillips #0 screwdriver.
  4. Acer Aspire 4741G-332G32Mn Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove all 12 screws from the backplate using a Phillips #0 screwdriver.
  5. Acer Aspire 4741G-332G32Mn Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using the prying tool to remove the bottom of the laptop.
  6. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: stap 6, afbeelding 1 van 2 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: stap 6, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the eight screws that hold the motherboard to the frame of the laptop.
    • Disconnect the USB port from the motherboard.
  7. Acer Aspire 4741G-332G32Mn Motherboard Replacement: stap 7, afbeelding 1 van 2 Acer Aspire 4741G-332G32Mn Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the 6 screws that hold the fan to the motherboard using the same screwdriver.
  8. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • Remove the motherboard from the device.
Conclusie
Christopher Carstairs
256 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S2-G6, Simcock Spring 2019 Lid van UMass Dartmouth, Team S2-G6, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G6
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 19
Altijd: 1,149
