Ga door naar hoofdinhoud
Acer Aspire 4520-5464 WiFi Wireless Card Replacement
Wat je nodig hebt
  1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement: stap 2, afbeelding 2 van 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: stap 4, afbeelding 1 van 2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: stap 4, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the two 0.5mm screws from the smallest panel on the back of the computer.
    • Set the screws aside.
    • Lift up the panel using the indent located on the left side of the panel.
  5. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Remove both the black and white wires by pinching the brass connectors and pulling up.
  6. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 0.5mm Phillips #1 black screws located on the WiFi card.
  7. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: stap 7, afbeelding 1 van 1
    • Lift the WiFi card on the left side to remove it.
Conclusie
To reassemble your device, follow these instructions in reverse order with a new WiFi wireless card.
Byeloth Hermanson
285 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,016
