Ga door naar hoofdinhoud
Acer Aspire 4520-5464 Hard Drive Replacement
Wat je nodig hebt
  1. Acer Aspire 4520-5464 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 4520-5464 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 2 van 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 3 van 3
    • Remove the seven 2mm Phillips #1 screws from the largest panel on the back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Hard Drive Replacement: stap 5, afbeelding 1 van 3 Acer Aspire 4520-5464 Hard Drive Replacement: stap 5, afbeelding 2 van 3 Acer Aspire 4520-5464 Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Remove the two 0.5mm Phillips #1 black screws left of the Hard Drive.
    • Remove the two 0.5mm Phillips #1 silver on top of the Hard Drive.
    • Lift up and remove the hard drive bracket by the plastic tab on top of the hard drive.
  6. Acer Aspire 4520-5464 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove the hard drive from the device.
Conclusie
Hunter Gilcrease
367 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 828
