Ga door naar hoofdinhoud
Acer Aspire 4520-5464 Graphics Card Replacement
Wat je nodig hebt
  1. Acer Aspire 4520-5464 Graphics Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Graphics Card Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 4520-5464 Graphics Card Replacement: stap 2, afbeelding 2 van 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Graphics Card Replacement: stap 3, afbeelding 1 van 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: stap 4, afbeelding 1 van 3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: stap 4, afbeelding 2 van 3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: stap 4, afbeelding 3 van 3
    • Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
    • Set the screws aside.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Graphics Card Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the four 0.5mm Phillips #1 screws located on the heat sink in numerical order, as labeled on the device.
  6. Acer Aspire 4520-5464 Graphics Card Replacement: stap 6, afbeelding 1 van 1
    • Using the traditional 2.5mm screwdriver, rotate the locking tab counterclockwise to unlock the graphics card.
  7. Acer Aspire 4520-5464 Graphics Card Replacement: stap 7, afbeelding 1 van 2 Acer Aspire 4520-5464 Graphics Card Replacement: stap 7, afbeelding 2 van 2
    • Lift up the heat sink line and remove the graphics card.
Conclusie
Hunter Gilcrease
367 Reputatie
3 handleidingen geschreven
Één opmerking
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
Fernando Rodrigues - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 27
Altijd: 2,376
