Ga door naar hoofdinhoud
Acer Aspire 4520-5464 CD/DVD Drive Replacement
Wat je nodig hebt
  1. Acer Aspire 4520-5464 CD/DVD Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 CD/DVD Drive Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 4520-5464 CD/DVD Drive Replacement: stap 2, afbeelding 2 van 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 CD/DVD Drive Replacement: stap 3, afbeelding 1 van 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: stap 4, afbeelding 1 van 3 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: stap 4, afbeelding 2 van 3 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: stap 4, afbeelding 3 van 3
    • Remove 7 of the 2mm Phillips #1 screw from the largest panel on back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 CD/DVD Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the .5mm Phillips #1 black screw located on the left side of the panel opening.
  6. Acer Aspire 4520-5464 CD/DVD Drive Replacement: stap 6, afbeelding 1 van 2 Acer Aspire 4520-5464 CD/DVD Drive Replacement: stap 6, afbeelding 2 van 2
    • Using the screwdriver, push the CD drive out of the laptop through the panel exposure.
Conclusie
Ethan Woltersdorf
270 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 14
Altijd: 419
