Ga door naar hoofdinhoud
Acer Aspire 4520-5464 Battery Replacement
  1. Acer Aspire 4520-5464 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Battery Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 4520-5464 Battery Replacement: stap 2, afbeelding 2 van 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Battery Replacement: stap 3, afbeelding 1 van 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
Conclusie
To reassemble your device, follow these instructions in reverse order using a new battery.
Byeloth Hermanson
285 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 11
Altijd: 438
