Ga door naar hoofdinhoud
Acer Aspire 3003WLCi RAM Replacement
Wat je nodig hebt
  1. Acer Aspire 3003WLCi RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
    Vraag FixBot
  2. Acer Aspire 3003WLCi RAM Replacement: stap 2, afbeelding 1 van 3 Acer Aspire 3003WLCi RAM Replacement: stap 2, afbeelding 2 van 3 Acer Aspire 3003WLCi RAM Replacement: stap 2, afbeelding 3 van 3
    • There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
    • Shift the bottom switch into an upward position in order to unlock the battery.
    • To unlock the upper switch, forcefully push the switch up and hold it in this position.
    Vraag FixBot
  3. Acer Aspire 3003WLCi RAM Replacement: stap 3, afbeelding 1 van 2 Acer Aspire 3003WLCi RAM Replacement: stap 3, afbeelding 2 van 2
    • While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
    • You may need to be a bit forceful when pulling the battery to the left if it hasn't been removed before.
    • You have to maintain pulling the upper switch upwards, or the battery will not come out.
    Vraag FixBot
  4. Acer Aspire 3003WLCi RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • The panel in the center of your device is the panel you will remove to replace the RAM.
    Vraag FixBot
  5. Acer Aspire 3003WLCi RAM Replacement: stap 5, afbeelding 1 van 2 Acer Aspire 3003WLCi RAM Replacement: stap 5, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, unscrew both 5mm captive screws on this panel.
    • The screws will not fully come out of the panel. This is intentional by the manufacturer.
    Vraag FixBot
  6. Acer Aspire 3003WLCi RAM Replacement: stap 6, afbeelding 1 van 3 Acer Aspire 3003WLCi RAM Replacement: stap 6, afbeelding 2 van 3 Acer Aspire 3003WLCi RAM Replacement: stap 6, afbeelding 3 van 3
    • Stick the tip of a spudger into the seam between the panel and the laptop body, on the side of the panel with the screws.
    • Use the spudger to pry up this side of the panel.
    • Grab the lifted side of the panel with your remaining hand and lift. You should hear a popping sound as the panel comes off completely.
    • During reassembly, you won't need the spudger. You'll simply need to replace and push on the panel until you hear it click back into place.
    Vraag FixBot
  7. Acer Aspire 3003WLCi RAM Replacement: stap 7, afbeelding 1 van 2 Acer Aspire 3003WLCi RAM Replacement: stap 7, afbeelding 2 van 2
    • Orient the laptop so that the battery is closest to you. The RAM slots are at the top of the laptop, and each stick of RAM has two tabs to hold it in its slot.
    • Remove both sticks of RAM. To do this, use both thumbs to push the tabs away from the desired stick of RAM. The stick should pop up at an angle when the tabs are pushed far enough.
    Vraag FixBot
  8. Acer Aspire 3003WLCi RAM Replacement: stap 8, afbeelding 1 van 2 Acer Aspire 3003WLCi RAM Replacement: stap 8, afbeelding 2 van 2
    • Use your thumbs and forefingers to pull the RAM out of its socket. Be sure to maintain the angle.
    • Repeat steps 4 and 5 for the second stick of RAM that lies underneath the first.
    Vraag FixBot
Conclusie
Tristin Viale
675 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G2, Bailey Spring 2019 Lid van UMass Dartmouth, Team S2-G2, Bailey Spring 2019
UMASSD-BAILEY-S19S2G2
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 1,053
