Inleiding
In this guide, you will be instructed on how to replace the internal fan in your laptop. The internal fan helps to remove hot air from inside your laptop, keeping the internal components from overheating and causing damage to your laptop.
This replacement is of moderate difficulty, but will take you no more than fifteen minutes to complete. It requires very few tools, and can be completed in 6 steps.
Wat je nodig hebt
Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
The panel you will be removing to access the internal fan is located at the bottom of the laptop.
