Ga door naar hoofdinhoud
Acer Aspire 3000 Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire 3000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Keyboard Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 3000 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Keyboard Replacement: stap 3, afbeelding 1 van 2 Acer Aspire 3000 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Lift the laptop to be on its edge, with the bottom of the screen in the air.
  5. Acer Aspire 3000 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the three 4.6 mm Phillips #1 screws that are on this edge.
  6. Acer Aspire 3000 Keyboard Replacement: stap 6, afbeelding 1 van 2 Acer Aspire 3000 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Wedge a spudger into the latch on the right side.
    • Open the lid completely to facilitate removal.
    • Pull the handle of the spudger towards you to pop the first of the tabs that hold this piece in place.
    • Starting from right to left, pop the remaining tabs by lifting up on the panel and rotating the panel to the left.
  7. Acer Aspire 3000 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the two 4.6 mm Phillips #1 screws.
  8. Acer Aspire 3000 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Gently lift the top edge of the keyboard out of its place.
    • Do not completely remove the keyboard as there is still a ribbon cable connecting it to the device.
  9. Acer Aspire 3000 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Lift the ZIF connector's black retaining flap. Then gently slide the ribbon cable out.
    • Remove the keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lykia Harper
258 Reputatie
2 handleidingen geschreven
Baylor, Team 4-2, Williams Fall 2016 Lid van Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 815
