Ga door naar hoofdinhoud
Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement
Wat je nodig hebt
  1. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: stap 2, afbeelding 2 van 2
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: stap 5, afbeelding 1 van 3 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: stap 5, afbeelding 2 van 3 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: stap 5, afbeelding 3 van 3
    • Disconnect the black and white antenna cables plugged into the network card on the motherboard.
    • Unscrew the four 5.5 mm Phillips screws holding the hinges of the monitor to the laptop frame.
  6. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: stap 7, afbeelding 1 van 1
    • Once the hinges are unscrewed the display assembly will easily come off.
Conclusie
To reassemble you will just follow these steps in reverse order.
AlexHarpring
301 Reputatie
3 handleidingen geschreven
Gateway, Team 1-1, Pee Fall 2023 Lid van Gateway, Team 1-1, Pee Fall 2023
GCC-PEE-F23S1G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 41
Altijd: 135
