Ga door naar hoofdinhoud
Acer AL1916 EMI Shield Replacement
Wat je nodig hebt
  1. Acer AL1916 EMI Shield Replacement, Stand: stap 1, afbeelding 1 van 1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 EMI Shield Replacement: stap 2, afbeelding 1 van 2 Acer AL1916 EMI Shield Replacement: stap 2, afbeelding 2 van 2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 EMI Shield Replacement: stap 3, afbeelding 1 van 2 Acer AL1916 EMI Shield Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
  4. Acer AL1916 EMI Shield Replacement, Outer Case: stap 4, afbeelding 1 van 2 Acer AL1916 EMI Shield Replacement, Outer Case: stap 4, afbeelding 2 van 2
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Acer AL1916 EMI Shield Replacement: stap 5, afbeelding 1 van 3 Acer AL1916 EMI Shield Replacement: stap 5, afbeelding 2 van 3 Acer AL1916 EMI Shield Replacement: stap 5, afbeelding 3 van 3
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Acer AL1916 EMI Shield Replacement: stap 6, afbeelding 1 van 2 Acer AL1916 EMI Shield Replacement: stap 6, afbeelding 2 van 2
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
  7. Acer AL1916 EMI Shield Replacement, EMI Shield: stap 7, afbeelding 1 van 2 Acer AL1916 EMI Shield Replacement, EMI Shield: stap 7, afbeelding 2 van 2
    • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
  8. Acer AL1916 EMI Shield Replacement: stap 8, afbeelding 1 van 2 Acer AL1916 EMI Shield Replacement: stap 8, afbeelding 2 van 2
    • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
  9. Acer AL1916 EMI Shield Replacement: stap 9, afbeelding 1 van 3 Acer AL1916 EMI Shield Replacement: stap 9, afbeelding 2 van 3 Acer AL1916 EMI Shield Replacement: stap 9, afbeelding 3 van 3
    • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
    • Lift up to remove the metal casing.
    • Beware, metal casing is sharp!
Conclusie
Taylor Atterbury
717 Reputatie
3 handleidingen geschreven
Cal Poly, Team 20-26, Maness Fall 2011 Lid van Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 1,256
