Ga door naar hoofdinhoud
Acer AL1714 LCD Replacement
Wat je nodig hebt
  1. Acer AL1714 LCD Replacement, LCD: stap 1, afbeelding 1 van 2 Acer AL1714 LCD Replacement, LCD: stap 1, afbeelding 2 van 2
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 LCD Replacement: stap 2, afbeelding 1 van 3 Acer AL1714 LCD Replacement: stap 2, afbeelding 2 van 3 Acer AL1714 LCD Replacement: stap 2, afbeelding 3 van 3
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
    • (This will require some force, you will hear a loud popping/snapping noises)
  3. Acer AL1714 LCD Replacement: stap 3, afbeelding 1 van 3 Acer AL1714 LCD Replacement: stap 3, afbeelding 2 van 3 Acer AL1714 LCD Replacement: stap 3, afbeelding 3 van 3
    • Remove the Power Button Circuit Board Flat Flex Cable from the Power Supply board under the metal cover.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 LCD Replacement: stap 4, afbeelding 1 van 3 Acer AL1714 LCD Replacement: stap 4, afbeelding 2 van 3 Acer AL1714 LCD Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the cord anchors for the VGA port.
    • (Use needle nose pliers if they're too tight for removal by hand)
  5. Acer AL1714 LCD Replacement: stap 5, afbeelding 1 van 2 Acer AL1714 LCD Replacement: stap 5, afbeelding 2 van 2
    • Turn the monitor around.
    • Unscrew the 1 screw holding the Flat Power Cable cover in place.
    • Lift up and remove the Flat Power Cable cover.
    • (Careful: it may be sharp)
  6. Acer AL1714 LCD Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the 5 screws holding the metal cage on.
  7. Acer AL1714 LCD Replacement: stap 7, afbeelding 1 van 2 Acer AL1714 LCD Replacement: stap 7, afbeelding 2 van 2
    • Lift up on the back of metal cage, slightly.
    • Pull the cage toward self.
    • (Must be careful to free cover of the VGA port and power supply input)
  8. Acer AL1714 LCD Replacement: stap 8, afbeelding 1 van 3 Acer AL1714 LCD Replacement: stap 8, afbeelding 2 van 3 Acer AL1714 LCD Replacement: stap 8, afbeelding 3 van 3
    • Lift up on the Flat Flex Cable holder tabs to release the cords.
    • Lift up on the Flat Flex Cables and bend them out of the working area.
  9. Acer AL1714 LCD Replacement: stap 9, afbeelding 1 van 3 Acer AL1714 LCD Replacement: stap 9, afbeelding 2 van 3 Acer AL1714 LCD Replacement: stap 9, afbeelding 3 van 3
    • Unplug the 4 backlight wires from their ports on the Power Supply board.
    • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling and pulling the wires out of place)
  10. Acer AL1714 LCD Replacement: stap 10, afbeelding 1 van 1
    • Unscrew the 5 screws holding the Power Supply and Video Display boards.
  11. Acer AL1714 LCD Replacement: stap 11, afbeelding 1 van 2 Acer AL1714 LCD Replacement: stap 11, afbeelding 2 van 2
    • Lift and remove the joined Power Supply and Video Display boards.
  12. Acer AL1714 LCD Replacement: stap 12, afbeelding 1 van 3 Acer AL1714 LCD Replacement: stap 12, afbeelding 2 van 3 Acer AL1714 LCD Replacement: stap 12, afbeelding 3 van 3
    • Carefully detach the Power Supply and Video Display boards at the connector joint.
    • (This step is not necessary to replace the LCD Module. This step is only a safety precaution so as not to bend or break the Power Supply connector joint)
  13. Acer AL1714 LCD Replacement: stap 13, afbeelding 1 van 1
    • Remove the Flat Flex Cable from the Power Button Circuit board.
  14. Acer AL1714 LCD Replacement: stap 14, afbeelding 1 van 3 Acer AL1714 LCD Replacement: stap 14, afbeelding 2 van 3 Acer AL1714 LCD Replacement: stap 14, afbeelding 3 van 3
    • Grasp, lift, and remove the LCD Module from the front panel.
  15. Acer AL1714 LCD Replacement: stap 15, afbeelding 1 van 1
    • The final product with the LCD Module removed.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Christopher Kelly
590 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Brown Fall 2014 Lid van USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 48
Altijd: 1,956
