Ga door naar hoofdinhoud
Accessing Samsung ML2510 Circuit Board
Wat je nodig hebt
  1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: stap 1, afbeelding 1 van 3 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: stap 1, afbeelding 2 van 3 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: stap 1, afbeelding 3 van 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Accessing Samsung ML2510 Circuit Board: stap 2, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Accessing Samsung ML2510 Circuit Board: stap 3, afbeelding 1 van 3 Accessing Samsung ML2510 Circuit Board: stap 3, afbeelding 2 van 3 Accessing Samsung ML2510 Circuit Board: stap 3, afbeelding 3 van 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: stap 4, afbeelding 1 van 3 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: stap 4, afbeelding 2 van 3 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: stap 4, afbeelding 3 van 3
    • Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
  5. Accessing Samsung ML2510 Circuit Board: stap 5, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Accessing Samsung ML2510 Circuit Board: stap 6, afbeelding 1 van 3 Accessing Samsung ML2510 Circuit Board: stap 6, afbeelding 2 van 3 Accessing Samsung ML2510 Circuit Board: stap 6, afbeelding 3 van 3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Accessing Samsung ML2510 Circuit Board: stap 7, afbeelding 1 van 3 Accessing Samsung ML2510 Circuit Board: stap 7, afbeelding 2 van 3 Accessing Samsung ML2510 Circuit Board: stap 7, afbeelding 3 van 3
    • Lift the right panel up from the raised stops.
    • Rotate the panel gently as indicated in the picture to remove the panel entirely.
  8. Accessing Samsung ML2510 Circuit Board: stap 8, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the four 1" screws attaching the gray plate to the printer.
    • Remove the plastic cover by sliding it carefully under the silver hinges on the right.
  9. Accessing Samsung ML2510 Circuit Board: stap 9, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the 1" screw attaching the circuit board to the printer.
  10. Accessing Samsung ML2510 Circuit Board: stap 10, afbeelding 1 van 2 Accessing Samsung ML2510 Circuit Board: stap 10, afbeelding 2 van 2
    • Turn over the circuit board to access main wiring.
    • Unplug the wiring from the circuit board gently.
Conclusie
3 andere personen hebben deze handleiding voltooid.
bbaustin
268 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-18, Regan Fall 2011 Lid van Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 2,856
