Ga door naar hoofdinhoud
Inleiding
The DC input of the Nokia 3100b is where the cell phone's charger plugs in to. This guide shows you how to access the input.
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure your phone is turned off.
    • Make sure your phone is turned off.
  2. Press the button on the back of the phone and slide the back panel off.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Note the small metal frame that  hold the SIM card into place.
    • Note the small metal frame that hold the SIM card into place.
    • Gently pull back the tab and lift open the frame.
  4. Retrieve your SIM card.
    • Retrieve your SIM card.
  5. Separate the front cover from the base.
    • Separate the front cover from the base.
  6. Using a T6 Torx screwdriver, remove the screws in the order of the colors of the rainbow.
    • Using a T6 Torx screwdriver, remove the screws in the order of the colors of the rainbow.
  7. Separate the screen assembly from the base.
    • Separate the screen assembly from the base.
  8. Note where the DC input is.
    • Note where the DC input is.
  9. Use a pair of tweezers to remove the DC input from the base.
    • Use a pair of tweezers to remove the DC input from the base.
  10. The DC input is now removed. Replace as necessary.
    • The DC input is now removed. Replace as necessary.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sterling Fuentes
61 Reputatie
8 handleidingen geschreven
Cal Poly, Team 29-64, Johann Spring 2010 Lid van Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 947
