Ga door naar hoofdinhoud
AYL SoundFit Speaker Replacement
Wat je nodig hebt
  1. AYL SoundFit Speaker Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Speaker Replacement: stap 2, afbeelding 1 van 1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Speaker Replacement: stap 3, afbeelding 1 van 1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Speaker Replacement: stap 4, afbeelding 1 van 2 AYL SoundFit Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Speaker Replacement: stap 5, afbeelding 1 van 1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Speaker Replacement: stap 6, afbeelding 1 van 3 AYL SoundFit Speaker Replacement: stap 6, afbeelding 2 van 3 AYL SoundFit Speaker Replacement: stap 6, afbeelding 3 van 3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
  7. AYL SoundFit Speaker Replacement, Speaker: stap 7, afbeelding 1 van 1
    • Using a soldering iron, heat up and remove the positive and negative wire contacts from the motherboard.
  8. AYL SoundFit Speaker Replacement: stap 8, afbeelding 1 van 1
    • Remove four Phillips #1 screws to detach the speaker form the module.
    • Extract the speaker from the body of the AYL SoundFit.
Conclusie
Sajal Kherde
107 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-3, Harley Spring 2016 Lid van IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 649
