Ga door naar hoofdinhoud
Inleiding
Use this guide to replace the battery of your AYL SoundFit. If your device's battery won't hold a charge, replacing the battery may resolve the problem.
  1. AYL SoundFit Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
  2. AYL SoundFit Battery Replacement: step 2, image 1 of 1
    • Place a spudger between the black plastic cover and the green case.
    • Pry the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Battery Replacement: step 3, image 1 of 1
    • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
    • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Battery Replacement: step 4, image 1 of 2 AYL SoundFit Battery Replacement: step 4, image 2 of 2
    • Remove the two Phillips #00 screws securing the battery casing.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Battery Replacement: step 5, image 1 of 1
    • Desolder the positive and negative battery contacts from the motherboard.
    • Remove the battery from the device.
Conclusie
Dustin Moore
108 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-3, Harley Spring 2016 Lid van IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Leden
5 handleidingen geschreven
3 Opmerkingen
Which battery is this, and what is the mAH?
jlongsa - Antwoord
3.7V 1500mAh, 5.55Wh
Coba Farr -
The charger works but it does not say chargeing
Zaira Cortes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 29
Altijd: 2,247
