Ga door naar hoofdinhoud
AUX-208P1 Electric Kettle Temperature Controller Replacement
Wat je nodig hebt
  1. AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: stap 1, afbeelding 1 van 2 AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: stap 1, afbeelding 2 van 2
    • Clean all the dirt on the bottom of the electric kettle.
  2. AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 2, afbeelding 1 van 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the three 19 mm screws at the bottom of the electric kettle.
    • Remove the base of the electric kettle.
    • Remove the LED indicator buckled on the base.
  3. AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 3, afbeelding 1 van 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 3, afbeelding 2 van 2
    • Use combination pliers to clamp the connection between the electric kettle line and the old temperature controller to create a gap, and pull it off.
    • Don't use too much force to avoid damage to the line!
  4. AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 4, afbeelding 1 van 1
    • Use combination pliers to remove the nuts holding down the old temperature controller.
  5. AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 5, afbeelding 1 van 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 5, afbeelding 2 van 2
    • Remove the broken temperature controller.
    • Clean the bottom of the kettle to remove any dust or debris buildup.
  6. AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 6, afbeelding 1 van 1
    • Align the socket on the bottom of the new temperature controller with the protrusion on the bottom of the electric kettle to assemble.
  7. AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 7, afbeelding 1 van 1
    • Use combination pliers to reinstall the nuts holding down the temperature controller.
  8. AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 8, afbeelding 1 van 1
    • Fasten the electric kettle circuit to the contact reed of the new temperature controller.
    • Gently pull the interface to ensure a firm installation.
  9. AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 9, afbeelding 1 van 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: stap 9, afbeelding 2 van 2
    • Re-buckle the removed LED indicator back to the base.
    • Buckle the base back to the bottom of the electric kettle.
    • Use a Phillips #0 screwdriver to three 19 mm screws on the bottom of the kettle.
Conclusie
重新组装设备时,请依次相反的拆卸顺序。
Één andere persoon heeft deze handleiding voltooid.
SHAN HUANG
193 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 61
Altijd: 1,279
