Ga door naar hoofdinhoud
ATT Trimline 210M Back Cover Replacement
Wat je nodig hebt
  1. ATT Trimline 210M Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Back Cover Replacement: stap 3, afbeelding 1 van 1
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Back Cover Replacement: stap 4, afbeelding 1 van 1
    • You will have the motherboard and speaker exposed to you.
  5. ATT Trimline 210M Back Cover Replacement, Back Cover: stap 5, afbeelding 1 van 1
    • Detatch the black and red wire from the back cover.
Conclusie
Juan Carrillo
406 Reputatie
3 handleidingen geschreven
USF Tampa, Team 4-2, Lacy Spring 2016 Lid van USF Tampa, Team 4-2, Lacy Spring 2016
USFT-LACY-S16S4G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 998
