Ga door naar hoofdinhoud
ATT EL52300 Keypad/Plastic Display Screen Replacement
Wat je nodig hebt
  1. ATT EL52300 Keypad/Plastic Display Screen Replacement, Battery: stap 1, afbeelding 1 van 2 ATT EL52300 Keypad/Plastic Display Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 Keypad/Plastic Display Screen Replacement: stap 2, afbeelding 1 van 1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 Keypad/Plastic Display Screen Replacement, Motherboard: stap 3, afbeelding 1 van 2 ATT EL52300 Keypad/Plastic Display Screen Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 Keypad/Plastic Display Screen Replacement: stap 4, afbeelding 1 van 2 ATT EL52300 Keypad/Plastic Display Screen Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 Keypad/Plastic Display Screen Replacement: stap 5, afbeelding 1 van 2 ATT EL52300 Keypad/Plastic Display Screen Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 Keypad/Plastic Display Screen Replacement, Keypad/Plastic Display Screen: stap 6, afbeelding 1 van 2 ATT EL52300 Keypad/Plastic Display Screen Replacement, Keypad/Plastic Display Screen: stap 6, afbeelding 2 van 2
    • The keypad lies on the top of the motherboard and is easily detachable.
    • Remove the keypad.
  7. ATT EL52300 Keypad/Plastic Display Screen Replacement: stap 7, afbeelding 1 van 1
    • Replace the plastic display screen, or the keypad buttons as needed.
Conclusie
Katty
313 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-1, Sullivan Spring 2016 Lid van USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 516
