Ga door naar hoofdinhoud
ATT CL4940 Internal Speaker Replacement
Wat je nodig hebt
  1. ATT CL4940 Internal Speaker Replacement, Internal Speaker: stap 1, afbeelding 1 van 2 ATT CL4940 Internal Speaker Replacement, Internal Speaker: stap 1, afbeelding 2 van 2
    • Unplug your device before beginning disassembly.
    • Remove phone line and power cord from the back cover of the device.
    • Remove phone cable from the side of the device.
  2. ATT CL4940 Internal Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Speaker Replacement: stap 3, afbeelding 1 van 3 ATT CL4940 Internal Speaker Replacement: stap 3, afbeelding 2 van 3 ATT CL4940 Internal Speaker Replacement: stap 3, afbeelding 3 van 3
    • Starting from the bottom of the device, use a metal spudger, separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using wire cutters, sever both the red and black wires connected to the speaker.
    • Carefully remove the speaker from the assembly.
    • Be sure to remove the rubber gasket from the broken speaker. You will need this for reassembly.
Conclusie
Charles Moore
201 Reputatie
2 handleidingen geschreven
IUPUI, Team 2-2, Harley Spring 2016 Lid van IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 398
