Inleiding
Over time and excessive use, the internal phone jack of the ATT CL2940 may become damaged. This can cause poor connection between the phone and the handset. Replacing the damaged internal phone jack will solve this problem.
Before beginning this project, it is always important to make sure you have the correct tools for the job. The tools that are needed are the pro tech tool kit, precision tweezers set and the metal spudger set. Once all these are acquired just follow the directions for an easy fix.
Wat je nodig hebt
Using the precision tweezers, bend the golden tips of the green and red wires upward.
Bend the wires slowly and gently to avoid breaking them.
Één andere persoon heeft deze handleiding voltooid.
