Ga door naar hoofdinhoud
AT-LP60X Setup Guide
  1. AT-LP60X Setup Guide, Place Turntable: stap 1, afbeelding 1 van 2 AT-LP60X Setup Guide, Place Turntable: stap 1, afbeelding 2 van 2
    • Place your turntable on a clear, flat surface.
    • Ensure there is no power connected to the turntable at this time.
  2. AT-LP60X Setup Guide, Locate and Install Platter/Belt: stap 2, afbeelding 1 van 1
    • Obtain the silver metal platter.
    • Verify that the belt is installed around the inner ring of the platter.
  3. AT-LP60X Setup Guide, Install Platter: stap 3, afbeelding 1 van 2 AT-LP60X Setup Guide, Install Platter: stap 3, afbeelding 2 van 2
    • Place the platter on the center spindle.
    • Rotate the platter to show the gold pulley of the motor.
    • Stretch the belt from the platter over the gold pulley of the motor.
  4. AT-LP60X Setup Guide, Preform Mechanical Reset: stap 4, afbeelding 1 van 2 AT-LP60X Setup Guide, Preform Mechanical Reset: stap 4, afbeelding 2 van 2
    • Place the slipmat on top of the platter and press the STOP button.
    • With your right hand, hold the tone arm in place.
    • [OPTIONAL] use the included hook and twist tie for this step.
    • With your left hand, rotate the platter clockwise about 10 times.
    • You should hear a series of clicks and pops.
  5. AT-LP60X Setup Guide, Reconnect Turntable: stap 5, afbeelding 1 van 1
    • Reconnect the power supply.
    • Connect the 3.5mm to RCA to your speakers.
    • For powered speakers the output switch should be in "LINE", if connecting to an amp/phono input the output should be in "PHONO"
    • The output switch position does not matter if you are connecting to a Bluetooth speaker.
  6. AT-LP60X Setup Guide, Prepare Tonearm: stap 6, afbeelding 1 van 3 AT-LP60X Setup Guide, Prepare Tonearm: stap 6, afbeelding 2 van 3 AT-LP60X Setup Guide, Prepare Tonearm: stap 6, afbeelding 3 van 3
    • Remove the clear plastic cover from the stylus (if present) by sliding the COVER ONLY directly towards the front of the turntable.
    • Unsecure the twist tie from the built-in hook (if present).
    • Ensure the tone arm lift button is in the outward position.
    • The setup is now complete and you are ready to try a record!
Conclusie
If you have any trouble setting up your turntable and/or a new problem arises, feel free to contact a technician at (330)686-2600 ext.5004 or service@atus.com
Één andere persoon heeft deze handleiding voltooid.
Anthony @ ATUS
1.195 Reputatie
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 54
Altijd: 606
