Ga door naar hoofdinhoud
ASUS ZenWatch Charging Cradle Circuit board Replacement
Wat je nodig hebt
  1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: stap 1, afbeelding 1 van 3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: stap 1, afbeelding 2 van 3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: stap 1, afbeelding 3 van 3
    • Using a metal spudger gently pry the plastic outer case apart
    • Pry open a little bit on each side before trying to open fully
  2. ASUS ZenWatch Charging Cradle Circuit board Replacement: stap 2, afbeelding 1 van 3 ASUS ZenWatch Charging Cradle Circuit board Replacement: stap 2, afbeelding 2 van 3 ASUS ZenWatch Charging Cradle Circuit board Replacement: stap 2, afbeelding 3 van 3
    • Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
    • Gently pry up with your hands to pull the board off.
    • Don't grab directly on the USB port as you may loosen or bust the connections.
Conclusie
Wayne McClure
961 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-3, Sullivan Spring 2016 Lid van USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Leden
7 handleidingen geschreven
Één opmerking
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
Nate Fansler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 2,881
