Ga door naar hoofdinhoud
ASUS ZenPad S 8.0 Motherboard Replacement
Wat je nodig hebt
  1. ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: stap 1, afbeelding 1 van 3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: stap 1, afbeelding 2 van 3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: stap 1, afbeelding 3 van 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Motherboard Replacement: stap 2, afbeelding 1 van 2 ASUS ZenPad S 8.0 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Motherboard Replacement: stap 3, afbeelding 1 van 3 ASUS ZenPad S 8.0 Motherboard Replacement: stap 3, afbeelding 2 van 3 ASUS ZenPad S 8.0 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Motherboard Replacement: stap 4, afbeelding 1 van 2 ASUS ZenPad S 8.0 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: stap 5, afbeelding 1 van 3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: stap 5, afbeelding 2 van 3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
  7. ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
    • The removing of the ribbon cable is done in the same way as the front facing camera.
  8. ASUS ZenPad S 8.0 Motherboard Replacement: stap 8, afbeelding 1 van 3 ASUS ZenPad S 8.0 Motherboard Replacement: stap 8, afbeelding 2 van 3 ASUS ZenPad S 8.0 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Using the tweezers remove the connector gently from the yellow slot
    • Gently peel up the tape until is is completely released from the motherboard
  9. ASUS ZenPad S 8.0 Motherboard Replacement: stap 9, afbeelding 1 van 2 ASUS ZenPad S 8.0 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Cut the warranty tape connecting the motherboard to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
  11. ASUS ZenPad S 8.0 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Gently lift the motherboard from your device
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jessica Voss
319 Reputatie
1 Handleiding geschreven
USF Tampa, Team 2-2, Cagle Fall 2016 Lid van USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Leden
5 handleidingen geschreven
2 opmerkingen
Where can I buy a spare motherboard for this device.
Partha Tripathy - Antwoord
Where are the motherboard sold and how do I purchase micro USB ports
Xibu Zhang - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 2,593
