Ga door naar hoofdinhoud
ASUS ZenPad S 8.0 Front Facing Camera Replacement
Wat je nodig hebt
  1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: stap 1, afbeelding 1 van 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: stap 1, afbeelding 2 van 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: stap 1, afbeelding 3 van 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
    Vraag FixBot
  2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: stap 2, afbeelding 1 van 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
    Vraag FixBot
  3. ASUS ZenPad S 8.0 Front Facing Camera Replacement: stap 3, afbeelding 1 van 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: stap 3, afbeelding 2 van 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: stap 3, afbeelding 3 van 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
    Vraag FixBot
  4. ASUS ZenPad S 8.0 Front Facing Camera Replacement: stap 4, afbeelding 1 van 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
    Vraag FixBot
  5. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 1 van 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 2 van 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
    Vraag FixBot
  6. ASUS ZenPad S 8.0 Front Facing Camera Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
    Vraag FixBot
Conclusie
John Astfanous
987 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-2, Cagle Fall 2016 Lid van USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 57
Altijd: 1,591
