Ga door naar hoofdinhoud
ASUS ZenPad S 8.0 Battery Replacement
Wat je nodig hebt
  1. ASUS ZenPad S 8.0 Battery Replacement, Rear Cover Removal: stap 1, afbeelding 1 van 3 ASUS ZenPad S 8.0 Battery Replacement, Rear Cover Removal: stap 1, afbeelding 2 van 3 ASUS ZenPad S 8.0 Battery Replacement, Rear Cover Removal: stap 1, afbeelding 3 van 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Battery Replacement: stap 2, afbeelding 1 van 2 ASUS ZenPad S 8.0 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Battery Replacement: stap 3, afbeelding 1 van 3 ASUS ZenPad S 8.0 Battery Replacement: stap 3, afbeelding 2 van 3 ASUS ZenPad S 8.0 Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Battery Replacement: stap 4, afbeelding 1 van 2 ASUS ZenPad S 8.0 Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
Conclusie
To reassemble your device, follow these instructions in reverse order. Ensure that the MicroSD card slot cover is in its closed position before re-attaching the rear cover.
29 andere personen hebben deze handleiding voltooid.
Samantha Brown
164 Reputatie
1 Handleiding geschreven
USF Tampa, Team 2-2, Cagle Fall 2016 Lid van USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Leden
5 handleidingen geschreven
20 opmerkingen
Thanks for this tutorial. Any chance anybody knows the part number for the battery and a good source?
danpobrien - Antwoord
Yes, A good tutorial but part number for the battery would be useful
celdor - Antwoord
Doh! its in the pictures its a C11Pn9H should have spotted that.
celdor -
The original battery says” Rating 3.8v 15.2 Wh” and “Capacity 4000mAh(TYP) 3984mAh(MIN)”
Clone batteries may be lower. Wish I’d bought a “factory battery”
license -
Tutorial was perfect, much easier than I thought. Unfortunately swapping the battery did not fix my tablet, but I feel a lot more confident now to try fixing things like this first instead of just automatically throwing them away. Thanks!
cdclemons - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 46
Altijd: 24,489
