Ga door naar hoofdinhoud
ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement
Wat je nodig hebt
  1. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Battery: stap 1, afbeelding 1 van 2 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 3, afbeelding 1 van 2 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 3, afbeelding 2 van 2
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • Peel back the silver tape.
  6. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the battery connections.
  7. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Speaker/Charger Port/Headphone Jack: stap 8, afbeelding 1 van 3 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Speaker/Charger Port/Headphone Jack: stap 8, afbeelding 2 van 3 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Speaker/Charger Port/Headphone Jack: stap 8, afbeelding 3 van 3
    • Remove all screws 3mm, using the Phillips #00 screwdriver, at the bottom of the device.
  9. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 9, afbeelding 1 van 1
    • Remove the black piece.
  10. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 10, afbeelding 1 van 2 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 10, afbeelding 2 van 2
    • Unplug the wires.
  11. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 11, afbeelding 1 van 3 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 11, afbeelding 2 van 3 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: stap 11, afbeelding 3 van 3
    • Using the pry tool, pry up the circular piece and remove the board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Henry Barrett
546 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 982
