Ga door naar hoofdinhoud
ASUS X550LB-DS71 Fan Replacement
Wat je nodig hebt
  1. ASUS X550LB-DS71 Fan Replacement, Fan: stap 1, afbeelding 1 van 3 ASUS X550LB-DS71 Fan Replacement, Fan: stap 1, afbeelding 2 van 3 ASUS X550LB-DS71 Fan Replacement, Fan: stap 1, afbeelding 3 van 3
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Fan Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
  3. ASUS X550LB-DS71 Fan Replacement: stap 3, afbeelding 1 van 3 ASUS X550LB-DS71 Fan Replacement: stap 3, afbeelding 2 van 3 ASUS X550LB-DS71 Fan Replacement: stap 3, afbeelding 3 van 3
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Fan Replacement: stap 4, afbeelding 1 van 2 ASUS X550LB-DS71 Fan Replacement: stap 4, afbeelding 2 van 2
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
  5. ASUS X550LB-DS71 Fan Replacement: stap 5, afbeelding 1 van 2 ASUS X550LB-DS71 Fan Replacement: stap 5, afbeelding 2 van 2
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
  6. ASUS X550LB-DS71 Fan Replacement: stap 6, afbeelding 1 van 2 ASUS X550LB-DS71 Fan Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
  7. ASUS X550LB-DS71 Fan Replacement: stap 7, afbeelding 1 van 3 ASUS X550LB-DS71 Fan Replacement: stap 7, afbeelding 2 van 3 ASUS X550LB-DS71 Fan Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Flip the motherboard to show the underside.
    • Locate the square fan connection attached to the motherboard.
    • Disconnect it using the tweezers (blunt).
  8. ASUS X550LB-DS71 Fan Replacement: stap 8, afbeelding 1 van 1
    • Remove the black tape from the fan as seen in the marked location.
    • At this point, the fan is now disconnected from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nathan Dyer
550 Reputatie
5 handleidingen geschreven
USF Tampa, Team S16-G1, Eyestone Fall 2017 Lid van USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 1,004
