Ga door naar hoofdinhoud
ASUS X533SA-BHCLN10 Fan Replacement
Wat je nodig hebt
  1. ASUS X533SA-BHCLN10 Fan Replacement, Battery: stap 1, afbeelding 1 van 2 ASUS X533SA-BHCLN10 Fan Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Fan Replacement: stap 2, afbeelding 1 van 2 ASUS X533SA-BHCLN10 Fan Replacement: stap 2, afbeelding 2 van 2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Fan Replacement: stap 3, afbeelding 1 van 2 ASUS X533SA-BHCLN10 Fan Replacement: stap 3, afbeelding 2 van 2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
  4. ASUS X533SA-BHCLN10 Fan Replacement, Fan: stap 4, afbeelding 1 van 3 ASUS X533SA-BHCLN10 Fan Replacement, Fan: stap 4, afbeelding 2 van 3 ASUS X533SA-BHCLN10 Fan Replacement, Fan: stap 4, afbeelding 3 van 3
    • Remove the three 5.5mm screws shown in the picture using the Phillips #0 screwdriver.
    • Carefully push the white connector out of the slot.
    • After removing the black electrical tape hold on to the side of the fan and lightly pull on the wire to remove the fan.
  5. ASUS X533SA-BHCLN10 Fan Replacement: stap 5, afbeelding 1 van 1
    • Remove the fan completely . attach electrical tape on the new fan for replacement.
Conclusie
Edmund Lee
473 Reputatie
4 handleidingen geschreven
USF Tampa, Team S13-G3, Boczar Fall 2017 Lid van USF Tampa, Team S13-G3, Boczar Fall 2017
USFT-BOCZAR-F17S13G3
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 362
