Ga door naar hoofdinhoud
ASUS X502CA Left I/O Board Replacement
Wat je nodig hebt
  1. ASUS X502CA Left I/O Board Replacement, Palm Rest with Keyboard and Touch Pad: stap 1, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Left I/O Board Replacement: stap 2, afbeelding 1 van 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Left I/O Board Replacement: stap 3, afbeelding 1 van 2 ASUS X502CA Left I/O Board Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Left I/O Board Replacement: stap 4, afbeelding 1 van 2 ASUS X502CA Left I/O Board Replacement: stap 4, afbeelding 2 van 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Left I/O Board Replacement, Left I/O Board: stap 5, afbeelding 1 van 2 ASUS X502CA Left I/O Board Replacement, Left I/O Board: stap 5, afbeelding 2 van 2
    • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
    • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
  6. ASUS X502CA Left I/O Board Replacement: stap 6, afbeelding 1 van 2 ASUS X502CA Left I/O Board Replacement: stap 6, afbeelding 2 van 2
    • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
    • Make sure the power strip is disconnected before pulling the board out.
  7. ASUS X502CA Left I/O Board Replacement: stap 7, afbeelding 1 van 2 ASUS X502CA Left I/O Board Replacement: stap 7, afbeelding 2 van 2
    • Slightly pull the unhinged screen up to free the board and remove it.
Conclusie
Christian Spencer
436 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 206
