Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
It is possible that your fan has stopped working due to physical or electrical damage. A replacement fan will need to be purchased. After purchasing a new fan follow these steps to replace the broken fan of your ASUS X502CA.
  1. First, remove all eleven phillips screws located on the bottom of the laptop using the Phillip #00 screwdriver.
    • First, remove all eleven phillips screws located on the bottom of the laptop using the Phillip #00 screwdriver.
    • Bottom 4 are 5 mm length, and the rest are 9 mm in length. All are 2 mm in diameter.
  2. Begin to remove the keyboard cover panel by using the Plastic Opening Tool to carefully pop off the clips around the parameter.
    • Begin to remove the keyboard cover panel by using the Plastic Opening Tool to carefully pop off the clips around the parameter.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. The keyboard cover panel is connected to the motherboard with ribbons, be careful to not damage them. Lift the keyboard cover carefully.
    • The keyboard cover panel is connected to the motherboard with ribbons, be careful to not damage them.
    • Lift the keyboard cover carefully.
    • Disconnect the keyboard and touch-pad ribbons using tweezers.
    • Remove the keyboard cover panel.
  4. Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
    • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
    • Disconnect the other connectors using tweezers or your finger nails.
    • If these are not unplugged, the motherboard may shock you.
  5. Unscrew the 6 Phillips #00 screws. Flip motherboard over away from screen.
    • Unscrew the 6 Phillips #00 screws.
    • Flip motherboard over away from screen.
    • Each screw is 5 mm in length with 1,5 mm diameter.
  6. Unscrew the 2 Phillips #00 screws.
    • Unscrew the 2 Phillips #00 screws.
  7. Unplug power connector using a tweezers or your fingers. Tear off the marked strip using your fingers. Now you can remove the fan.
    • Unplug power connector using a tweezers or your fingers.
    • Tear off the marked strip using your fingers.
    • Now you can remove the fan.
Conclusie
6 andere personen hebben deze handleiding voltooid.
David Conner
292 Reputatie
2 handleidingen geschreven
Clemson, Team 14-1, Shirley Winter 2015 Lid van Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Leden
5 handleidingen geschreven
Great tutorial.
Arthur Rumrill - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 52
Altijd: 7,009
