Ga door naar hoofdinhoud
ASUS X44H-BBR4 Keyboard Replacement
Wat je nodig hebt
  1. ASUS X44H-BBR4 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 ASUS X44H-BBR4 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Open the laptop to show the keyboard.
  2. ASUS X44H-BBR4 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
  3. ASUS X44H-BBR4 Keyboard Replacement: stap 3, afbeelding 1 van 3 ASUS X44H-BBR4 Keyboard Replacement: stap 3, afbeelding 2 van 3 ASUS X44H-BBR4 Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
  4. ASUS X44H-BBR4 Keyboard Replacement: stap 4, afbeelding 1 van 2 ASUS X44H-BBR4 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
  5. ASUS X44H-BBR4 Keyboard Replacement: stap 5, afbeelding 1 van 2 ASUS X44H-BBR4 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Flip the keyboard over to reveal the back of it and what is underneath.
  6. ASUS X44H-BBR4 Keyboard Replacement: stap 6, afbeelding 1 van 3 ASUS X44H-BBR4 Keyboard Replacement: stap 6, afbeelding 2 van 3 ASUS X44H-BBR4 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
  7. ASUS X44H-BBR4 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the keyboard completely.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kelly Merlo
500 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-3, Catania Fall 2015 Lid van UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,198
